Wow...
d19rye said:
I had to put my seat all the way down to be able to touch my feet down while i sit. But I dont like it low like that i want it higher. So is that what alot of people do, Have the seat up high and not be able to touch the ground while sitting down. So if you stop riding you have to stand up to be able to touch or what?
... I'm impressed with the newbie questions. Keep 'em coming.
Have you checked the beginner forum?
Your next questions:
You get the best power to the pedals (and least knee soreness) if you keep the saddle high enough so your knee is barely bent when the pedal is all the way down.
No bicycling won't make you impotent... not unless you ride 7 hours a day every day, and even that is questionable..
30-35 PSI is a good tire pressure to start with
You have to push the bead down in the low part of the rim to get the tire off.
Glueless patches suck
No, you can't fix a tire and ride home by stuffing it with leaves.
Lean back, do one good pedal stroke while pulling back on the bars
Bend your knees, put your behind over the back wheel, and pinch the saddle between your knees. Don't death-grip the bars.
Yes, you will probably fall over a couple times when you first do clipless pedals, but practice on the lawn, and you'll be fine.
Of course you get chainsuck. That's what happens when you shift from middle to granny gear under load. Learn to soft pedal while shifting, and it probably won't happen.
Lube your chain after every ride, not before. That way, the lube has more time to soak into the chain for next time
