I might be wrong but it seems that when it compresses it would crack but I dont know, I'm sure there is a special type of paint out there, I bet that a local powder coater or anodizing company would be able to do it for you.
I know you can buy paint in a spary can for plastics. Maybe that would take the springy action good. You can buy that hobby RC paint as well. That should hold up too but Im just guessing at that since it works good on my RC trucks body I painted only the scratches show. I forget what type of paint that was though.milhouse said:I know this is a stupid question but I was wondering if I could paint the shock spring from my 6-way without it all flaking off in a few rides. Is there a special paint that's used form the factory that is more flexible then what you can get at Home Depot?
I was also thinking of soaking it in paint stripper and spraying a clear coat over the bare metal. Any pointers?
Thats what I was thinkingCOmtbiker12 said:I might be wrong but it seems that when it compresses it would crack but I dont know, I'm sure there is a special type of paint out there
If you drop it off at a place that does powder coating and tell them that you want it painted next time they do XXXXX color, they will probably only charge you about $15 for it (since they don't have to do the setup twice). I had a romic spring that was painted grey by a powdercoating place. No problems/flaking at all, since that's how most spring are painted to begin with. If you will pay for setup, they will paint it whatever color you want right away.milhouse said:I know this is a stupid question but I was wondering if I could paint the shock spring from my 6-way without it all flaking off in a few rides. Is there a special paint that's used form the factory that is more flexible then what you can get at Home Depot?
Thanks. Did you have to strip off the original powder coating? Would I look in the yellow pages under powder coating?robsetsfire said:If you drop it off at a place that does powder coating and tell them that you want it painted next time they do XXXXX color, they will probably only charge you about $15 for it (since they don't have to do the setup twice). I had a romic spring that was painted grey by a powdercoating place. No problems/flaking at all, since that's how most spring are painted to begin with. If you will pay for setup, they will paint it whatever color you want right away.
MRP.skywaybuzz said:Soap what rollers are they on your MRP
Thanks for your help. What do I look for in the yellow pages to find people that do powder coating? I looked under powder coating with no luck. Would it be Automotive Painting?Gman086 said:Like other have said - bring to a powder coater. They do lots of springs (mainly automotive in custom colors, I've seen some blue ones that look really kewl). They will use a thermoplastic resin that will last about a thousand times longer than Krylon.
G MAN (yes, coatings additives IS my business so I know the gig)
The guy who did it just dropped it off at the PC place... no removal of old paint.milhouse said:Thanks. Did you have to strip off the original powder coating? Would I look in the yellow pages under powder coating?
