Can someone school me on clip pedals (peloton)
695 Views 5 Replies 4 Participants Last post by  Noplacelikeloam
I've never used clip pedals before. We just got a peloton and I want to swap the pedals out for ones that do both flat and clip. I believe the clips on our shoes are SPD, but when I search them, they look different (ours have 3 bolts, ones I see on-line have 2). Are there different types?
1 - 6 of 6 Posts
two bolt are mountain bike SPD, three are road. (technically SPD and SPD-SL, but you know.. )
  • Like
Reactions: 1
Depending on if you share, you can buy pedals that have a look cleat on one side and SPD on the other. Try amazon.
  • Like
Reactions: 1
I believe all peloton come standard with look delta style pedals. To use spd, you’ll have to change pedals and cleats (and most likely shoes as most are either 2- or 3-bolt, not both). I don’t know if any two-sided delta pedals.
  • Like
Reactions: 1
So the SPD-SL and Look Delta are different? So something like these won't work?
https://www.amazon.com/Thinvik-Clip...ocphy=9004517&hvtargid=pla-446570476533&psc=1
Edit
Just seeing these...I think this will do the trick!
https://www.amazon.com/ATP-Sports-P...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
1 - 6 of 6 Posts
