Opening the low speed more will cause the high speed to open later, as you are allowing more oil flow through the low speed needle. The high speed stack will only open when the pressure of the oil becomes high enough to push it open because the pressure pushing through the low speed has reached a high enough level. Chatter is a high speed event, so you should be opening up your high speed. A few other items:
1) Dropping pressure will likely not help and probably make it worse. As you drop pressure you put the fork into the steeper part of the air curve, so it will get harsher on chatter.
2) Pay attention to rebound, too much rebound will cause the fork to be stuck down, putting it in the steep part of the spring curve and creating harshness.
4) Tire pressures are important, Assuming you have the stock 35mm internal wheels, your front tire pressure should be about 20psi to start with and likely will end up lower.
5) Forks tend to bed in over the first few rides. Do not be suprised if after 5-10 rides the fork feels much different than it does now.
Enjoy it, great bike.
