More info would have helped. I had to Google Gary Fischer Cobia to find out that it has a RockShox Tora Race Solo Air 29 fork on it then I had to Google that to find out that the maximum recommended rotor size is 210mm.
Having said all that, there is no reason that you can't do it nor any reason that you shouldn't do it. The 203mm front rotor will give you a lot more braking power but it may be overkill, depending on your weight.
