1 - 2 of 2 Posts
· Registered
I would like to purchase another wheel set for my 2009 Gary Fisher Tassajara. The bike comes stock with Shimano M486, hydraulic disc, 160mm CenterLock rotors brakeset. The picture below are the Shimano resin brake pads. What I would like to know is that, can I purchase any make and model 160mm brake rotors and be safe using these B01S resin pads?
· Registered
You should be able to use any rotor with resin pads.
I've read that some rotors that come with the lower end shimano are only rated for resin pads, so you may want to look into that if you ever want to change to met/cer pads.
1 - 2 of 2 Posts
