1 - 8 of 8 Posts
Hello I have an Tracer, 2002 model and want to run a Vanilla Coil 165mm - 900lbs x 1.5 Shock. Would this be okay, will it damage the frame, or seat post???
Thanks.
www.derbyrims.com
Thanks.
It will fit. The 900# spring might be good for a very heavy rider, maybe over 225 lbs.
I'm 200 lbs plus gear and use a 700 spring on my Tracer with Vanilla-R.
Don't use too light a spring, it if bottoms a lot it can help accelerate the seat tower to fail.
Air is nearly impossible to bottom on the Tracer. I think these days I'd go with the new RP3 air shock if I was to upgrade from the original Float RL. Although my old style, non-propedal Vanilla-R is butter, and has required no maintenance except the normal bushing replacement in 3 years. A Fox tech said I should get the internal oil changed every year or two even without any obvious problems.
- ray
Trail Rider
I bought one for a backup shock when I send the Float in for service. I contacted Fox and they suggested #800 for a 185 lb rider without gear. I found it plusher than the Float RL that came on the frame. I was able to hit the black rubber stop a few times(bottom out). I didn't like the bouncy feel of the shock. I had to crank up the rebound dampning to get that to stop. I prefer the air shock for climbing. It is good for a backup or better yet, get the RP3 and keep the Float for a backup. I put an AVA sleeve on mine(Float) and get slightly more stroke on the shock.I get just over 4 in. of travel.
www.derbyrims.com
I must have a much more forward riding position than you. (WTB Laser seat adjusted on center of Thompson). I rarely if ever harshly bottom a 700# spring under my 200 lbs, rebound right in the middle of the range, I do use the bump stop sometimes, but that's OK by design. 750# spring is noticeably more bouncy and harsh, it also needs slower rebound. I don't do many larger jumps though, and only to rather smooth transition. I do notice most Tracer riders like firmer suspension than me, or platform shocks, which feel harsh to me too. Maybe I'm just off the scale weird!
- ray
Trail Rider
- ray
I hit the bumper when I was not doing a jump. I am off the seat when jumping(in back).
I have hit the bumper when at a slow to moderate speed in very rocky conditions. I felt the bumper hit and I might not have had my weight off the seat or something. I didn't like the feel of that. It was harsh and not like my Float. I do realize how conditions could be perfect for a broken frame even though they are not doing jumps or fast DH runs.
I'd probably like the coil shock on a 6 in. travel bike. I'm such a weight weenie that It bugs me just putting the coil shock on my Tracer (I'm such a weight weenie) . I'm going to get an air shock on the rear on my next longer travel frame.
www.derbyrims.com
Rp3
Having test ridden the RP3 recently, I'd get that now for my Tracer instead of a Vanilla-R (without pro-pedal), if I just had the original air shock that didn't get full use travel. I like light weight too.
Although one other advantage of a coil is it doesn't equalize air into the damper chamber so recharge intervals are much longer. My coil is still working like new after 3 years (except the common 6 month lower bushing change interval). A ti coil would be nearly as light as air, but getting the right spring would take some testing with steel coils for a while to know what weight works best.
You may ride harder than me too and need more spring.
- ray
Discussion Starter · #7 ·
Thanks for the replies, the coil was a cheap replacement as the original FOX is pretty dead, the Tracer will become a third bike in a shortwhile , been a great bike and don't want to let it go so just need something effective, cost sensitive and operational, so it seems the Vanilla will do.
Thanks.
I am around the 195-200 range....I prefer the heavier springs as well.....(when I use the vanilla).......as mentioned earlier it will depend on your riding postion....in relation to your frame size.
1 - 8 of 8 Posts
