I mean the shaft on my rear shock ;^>
I got a Swinger 4-way Air pretty cheap off of ebay, but the catch was it came off a bike that was damaged in a fire. It holds air in both chambers and looks just fine. You would not know it was exposed to fire other than it smells like a campfire. However, there is one spot on the shaft that is a little rough (I knew about this when I bought it). It's not bad, but you can feel it when you rub your finger over it. It's a circular spot about 1/4" across. What concerns me is that it is right where the sag point will be, so it will be in constant contact with the dust seal. I am wondering if I can (or should) use some super fine grit sand paper to smooth it out.
What do you think?
What do you think?
