1 - 4 of 4 Posts
I have a Northrock XC00 Fat bike with 26x4" tires.
It has an oddball 120-121mm front fork dropout.
I measured 55-56mm from the outside rim edges. Take off a 1-2mm per side makes it 52mm or (50mm to make things even).
I want to be able to put on a smaller tire, from the rim to tire graphs it looks like you can go 1.5X the rim edge width to about 2 or 2.5X.
50mm x1.5 = 81mm(3.18") and 50x2=100mm(3.93")
Can I install a 3.00" tire on that 50mm rim and be alright?
Discussion Starter · #3 ·
Thanks, all the charts I've seen havent showed wide rims, I am sure they are out there.
I just found this, interesting read.
https://bikerumor.com/2016/08/12/tech-story-match-bicycle-tire-width-rim-width-best-results/
Basically it states:
4.8"-5" is 90mm Inside Width rim
3.8-4" is 75-80mm for snow, and narrower as 50mm with high pressure for summer riding.
"a good starting point is likely using a rim with an inside width of 50-65% of your tire width."
1 - 4 of 4 Posts
