Pressure is an empirical thing. Only you can determine what you can get away with with a particular tire at your weight. Riding technique and terrain also both come into play when you start trying to push pressure to the lowest limit. Even then there is that unexpected "hit" that can cause the tire to bottom out, so don't try to push it too far or you will start putting dings in your rims.
