The coil side of my Lyrik started to leak, and after changing the crush washer a couple of times realized that wasn't the problem.
I tried jb weld after proper prep after that didn't work tried regular epoxy with no luck. It still leaks. If it wasn't my brake side I might not care. The crack is the dark line
Don't have the cash for a new fork right now
Questions
- Any other way to fix the crack
- A small amount of oil is in this leg 20ml just to lubricate. Can I just pack it with judy butter (grease) I'm guessing without proper lubrication the parts will start to wear.
Questions
