I own an A9C with a tapered tube XX fork. I recently had the wheels relaced with heavier spokes (17g from revolutions). I also swapped from Flow rims to Arch rims. The difference was day and night as far as tracking and corning (much tighter radius). I now want to stiffen up the front axle as I am now using a Hope SS skewer and still getting a bit of flex.
My dilemma is that my RS does not offer 15mm TA lowers and my hubs will not convert to 20mm. Therefore, I decided to look at the DT Swiss RWS 9mm skewers. Now I can't find 9mm end caps for my ISO CK's. Does anyone foresee a problem with having my current end caps drilled to 9mm at a local machine shop? This would also remove the steel tabs that the fork rests on when the wheel is locked in. However the Swiss skewer would take care of that.
Any help is greatly appreciated.
