IIRC, DT does conversion kits for its own rims, but you could do a "ghetto" (use search function) conversion which would be cheaper.
Its upto you which you feel more comfortable with.
It works with alot of tires (both wire and folding, 1 and 2+ ply, etc) - but those with weak beads (Stans/Notubes recommended list) will "roll off" easily, and those with thin sidewalls wont last too well. Some tires will leak sealent through the sidewalls and be near impossible to get sealed - search for conversions on specific tires (the most common tires will likely have posts about them).
Aslong as the bead is good and the sidewalls arent scary thin, you should be fine with a conversion.
Ideally, a UST tire would be best (brand is irrelevant, so you could ignore the notubes list here) because they're made specifically for tubeless and have stronger beads and suitable sidewalls.
