1 - 8 of 8 Posts
yes, but You'd need to purchase a 120mm air shaft and install it. This will involve owning snap ring pliers, some sram butter to relube your seals and some rock shox oil to refill your lowers when you're done. If you're not mechanically inclined, any bike shop that services suspension should be able to do it for you.
is basically how most rockshox air fork air shaft swaps go.
100mm is max
Yeah, the Reba A7 and A8 came in 3 versions - a short stanchion (max 100mm), medium stanchion (max 120mm), and long stanchion borrowed from the 32mm Revelation (max 150mm).
The 120mm max travel version has 80mm and 120mm gradients on the stanchion, the 100mm max travel has 80mm and 100mm gradients.
This is 100mm max.
1 - 8 of 8 Posts
