Hi, I'm putting together an old Bontrager Race frame as a SS (It's a 1992). It's got the forward facing horizontal dropouts that allow me to adjust the slack. I'm using bolt-on hubs also.
I had one of these frames new back in the day, and I swapped it out when Bontrager went to a horizontal dropouts in 1993 because I was able to slide the rear hub in the dropout when I cranked up a hill and make the tire slam into the inside of the non-drive chainstay. (This was a geared setup with QR's) The Bontrager dropouts were cut out of a very hard steel that does not allow as much "grip" as most dropouts do.
I'm wondering if anyone can recommend a chain tug that will work on a forward facing horizontal dropout? I don't mind a little bit of dremel'ing to make it fit, but I'd like to start with one that is a reasonable good fit.
Any insights to share?
