The '02 and earlier SB get their own linkage that mimics the '04 5" linkage, and results in 5.25" travel. You can run a Fox AVA R, I am. Altho I would recommend picking up an older Float for cheaper and having it Push'd. It rocks...jrm said:And can i use a Fox AVA R Propedal instead of the 5th air?
So what happens to the geometry numbers when you add the link and say a talas fork. I would be using a propedal or pushed shock on the frame. Im running one now on a tracer and its great.dbabuser said:The '02 and earlier SB get their own linkage that mimics the '04 5" linkage, and results in 5.25" travel. You can run a Fox AVA R, I am. Altho I would recommend picking up an older Float for cheaper and having it Push'd. It rocks...
