Hi, all. I'm thinking of buying a Kona Caldera or a Cinder Cone. Unfortunately, though, the bikes aren't stocked nearby, so I would have to order. Before doing so, I've got a couple of questions about size and weight. I could really use some help from this forum.
First, I'm 5'8" tall with about a 30-31 inseam. Would I be better off going with a size 16 or a size 17. I'll be riding mostly XC, less technical stuff.
Second, I've read a couple of reviews that say these bikes are heavier than other brands' comparable hardtails. Do you find this to be true? How much heavier?
The tech specs on Kona's web site list the Caldera at 27.6 lbs (17") and the Cinder Cone at 28.7 lbs (16"). Do these weights tend to be accurate? If not, any idea what the actual weights are of these two bikes with their stock setups.
Any help would be appreciated.
