I know several people with the bikes in question. They have no more or less chainsuck than any other bike.Fisty said:The fuel, sugar and couple others are well noted for it! Just check the reviews.
IIRC part of the problem on the earlier Sugars et al was the Bontrager chainrings. Shimano rings worked better as do the newer Bonty rings.Fisty said:Well it has been a few years since it was a hot topic so maybe it is resolved. I have a two 02 Sugar 1s that I have dealt with for some time. I pretty much have them suck free at this point but, still the occasional problem. I probably should have stated that in my post rather than being so general. I have redone both of the driveside chainstays for better clearance when the do suck. As far as feeling the presuck in the drive, that is a given. They just are very quirky and quick to suck on shifts and also with less than full power on the pedals.
Ding. Ding. Ding. We have a winner. A year or two ago Trek issued a warrantee or recall replacement of the Bontrager (Truvative) middle ring, the notice was posted on their website.shiggy said:IIRC part of the problem on the earlier Sugars et al was the Bontrager chainrings. Shimano rings worked better as do the newer Bonty rings.
deathonwheels said:I had a GF Sugar 3+ witch chain sucked all the time. I went through the typical warranty protocol after checking chainline, proper lubrication, chain, chain teeth, front rings and finding out that these were not the sources of the chain suck.
I forgot to mention that this bike was BRAND NEW. So these "worn drivetrain" excuses floating around does not apply with the GF genesis frames/bikes.
I have been trying to tell people this for years, but if they want to continue amusing themselves with excuses, juggling new parts and throwing $$$ in the garbage, what can you do??? I battled with GF warranty and tried to explain this to them when I bought my sugar, and I know it was obvious to them already, but why would they fess up to it if it meant losing $$$ at that time. So remedied the situation by selling the P.O.S. frame. I have to give GF credit for amusing me and sending me a replacement frame despite the fact that they knew it was worthless. What else could they have done, you can't recall bike frames.punkassean said:Trek told me that due to the short chainstays (Genesis geometry) there is less clearance than normal on the Cakes between the chainrings and the chainstay and that is a BIG part of the chainsuck problem. Also once the frame gets marred from one bad suckage () it will be more likely to happen again and again. We've had a few Cakes with perpetual suckage and we've tried EVERYTHING to no avail. I used to believe chainsuck was striclty limited to a bad setup or poor maintenance but now I realise there are other issues too such as bad frame design. Sticky crappy grade aluminum chainrings don't help but are not the real culprit ultimately.
I will only say not everyone with a Sugar has the problems you did.deathonwheels said:I have been trying to tell people this for years, but if they want to continue amusing themselves with excuses, juggling new parts and throwing $$$ in the garbage, what can you do??? I battled with GF warranty and tried to explain this to them when I bought my sugar, and I know it was obvious to them already, but why would they fess up to it if it meant losing $$$ at that time. So remedied the situation by selling the P.O.S. frame. I have to give GF credit for amusing me and sending me a replacement frame despite the fact that they knew it was worthless. What else could they have done, you can't recall bike frames.
As what is already obvious to us all and beaten to death is that NOT ALL SUGARS CHAINSUCK.shiggy said:I will only say not everyone with a Sugar has the problems you did.
I think the "problem" was not actually chainsuck, but the chain jamming between rings and stays after the chain drops off trying to shift from middle to small ring (same end result as chainsuck but with a different source) - that's the only time I've ever had this "problem" on my Fuel....I believe the majority of time it's not true chainsuck, but....semantics, I guess. Never had enough trouble with it to consider it a "problem". Keeping drivetrain clean, dialing drivetrain, and not shifting under extreme loads has all but eliminated it happening to me.Fisty said:Did anyone ever come up with an explanation for why these rigs were so suceptable to chainsuck? There were alot of "guesses" but, I never actually heard what the definate cause was.
If the bikes are the same and the drivetrain is the same and the setup is the same and one rider has problems and another does not the simple answer is obvious.deathonwheels said:As what is already obvious to us all and beaten to death is that NOT ALL SUGARS CHAINSUCK.
I agree with you as I have spoken with many GF sugar owners who never had chainsuck problems, but their drivetrain setups were the same as mine (stock). So I am left with assuming - being that their bikes were no different than mine - that the chainsuck is independent of drivetrain setup or else they would be experienceing chainsuck as well. This is especially true if the Bonty chainrings are at fault, but I had chainsuck and they didn't. Also I gave my stock crankset to my friend who rides with them on his bike and guess what - he does not have chainsuck. So I am left with looking at the most simple explaination... hmmm.... maybe the frame??? But it was not worth any more of my time and money to investigate. All I can say is what I already stated in above post - for those who never had problems with chainsuck, you are lucky, so enjoy the ride. The same goes for any other bike or component - I see many negative posts about components and bikes that I have or had used and never expereinced the problems that these reviewers complain about, but you know what and READ THIS WITH YOUR FULL ATTENTION - just because you do not experience the same problems as others talk about does not mean that the problem does not exist.
Yes indeed the chain would jam between the granny and the chainstay when it dropped or sucked. I reworked that area of the chainstay so that rather than jam when it sucks it just drops on bb housing. I have fiddled and faddled with my sugars and I still have some issues with chainsuck still but at least my chain granny and stay dont get destroyed. With regard to My original question in the original post, I guess the answer is no, they never did find the answer. Thanks for all your input!Fuelish said:I think the "problem" was not actually chainsuck, but the chain jamming between rings and stays after the chain drops off trying to shift from middle to small ring (same end result as chainsuck but with a different source) - that's the only time I've ever had this "problem" on my Fuel....I believe the majority of time it's not true chainsuck, but....semantics, I guess. Never had enough trouble with it to consider it a "problem". Keeping drivetrain clean, dialing drivetrain, and not shifting under extreme loads has all but eliminated it happening to me.
