I've got a lot of noise coming from my rear wheel and frame under braking. It sounds like Gilbert Godfree gargling nails with a megaphone. It's just started happening three or four rides ago and there haven't been any equipment changes to inspire these new noises. It's not a squeal or a squeak, but an unholy ringing/groaning with vibrations that I can feel through my feet. It starts as a high-pitched ringing and builds with volume and even sounds like all the spokes are vibrating with it.
I've swapped out between three different rotors to make the noise go away and was unsuccessful (Shimano 6-bolt Doere-level, Mugura Storm SL, and Avid G2, all 160 mm). I also switched pads from metallic to resin. I also put noise damping paste on the back of the pads. Going through all these iterations systematically I managed to waste most of a Sunday. No change in the pitch or tone from Gilbert.
The more I think about it, the more I think the cassette is playing a big role in responding to the vibrations under braking and amplifying them. The problem is I've checked the cassette and it's tight to the freehub, but the freehub has a little bit of play in it. The wheelset is in good shape, but easily has 400 miles on it, all on dusty Southeastern trails. I think that a freehub replacement might be what is needed. There is a little play, but not enough for me to really measure. Also, the axle spins smoothly without play or binding so I think I can eliminate the axle as a contributor.
Before I spend any more money I wanted to check with you guys if you've had trouble with the stock 495/505 Shimano calipers that come stock on a 2011 XTC 1. Again, the bike was dead silent under operation until just a few rides ago, and with no equipment changes, I'm lead to believe that something has worn enough to allow this vibration to creep in.
What do you guys think?
