1 - 3 of 3 Posts
I am starting to buy some necessary tools to change the gear cables of my bike.
I would buy a shimano cable cutter; some hex wrenches and does it necessary the cable stretcher or a simple plier do the work?
Loose Nut Behind d' Wheel
I've been riding and wrenching on bikes for over 25 years, and I still don't understand (nor need) the function of a cable stretcher. The cable cutter and hex wrenches are essential - I like Bondhus ball drivers for hex wrenches (available at Home Depot and other hardware stores). A small, fine file for deburring the housing ends is also good to have. Have fun!
Kathy :^)
The only time I've ever used it was setting the low limit by cable tension. Like when the
lower limit screw is frozen, or the head mangled beyond hope. I can use it to hold the
front derailleur and cable and tighten the binder. Otherwise the are in the way and kept
under the bench out of sight. ;)
1 - 3 of 3 Posts
