Thought I'd share a couple of pics of a quick, easy and useful mod I did to my BW.8 lowers while I was servicing the fork today, i.e. the Press-Fit Zerk Fitting Mod. In hindsight, I probably should have taken some step-by-step pics, but it's not like it's all that complicated of a procedure, anyway. Simply center-punch the zerk locations (19mm down from the top of the factory seals puts them about dead center in the lube cavity between the seals and the upper bushings), then drill away. I use a 1/16" bit to make a pilot hole, but you could probably get away with drilling the necessary 1/8" hole straight-away. A few taps of the hammer later, and those zerks aren't going anywhere, ever. They're the perfect way to keep those upper bushings lubed. If Enduro seals ever become available for WB forks, I'll put a set of those in, for sure.
-tw-
-tw-
