Hello. I need some advice from the experts here!
I want to take off some weight from my disc wheelset by switching the spokes from straight to butted, and maybe the brass for alloy nipples too. This is the current spec:
Front
155----xtr 960 disc hub
397-----mavic 717 disc
222------Dt 2.0 straight(32pcs,avg 264mm)
41------Brass long nipples (32)
815 Total
Rear
311xtr 960
397mavic
222spokes
41nipples
971 Total
Front +rear=1786
My idea is switch to DT revolution 2/1.5/2 with a saving of 80 gms per wheel (according to my scale measurment compared with the weight weenies listings)
And the alum nipples would take 20 gms per wheel.
That would leave the current 1786 gms whelset at 1586. Not bad at all! And I can keep the hubs (which I love) and the rims, making it kind of affordable upgrade(revolutions aren´t cheap, but cheaper than new rims or hubs, aren´t they?)
Now, I weigh 167 lbs, bike is a steel hardtail (RM blizzard) fox fork and xtr discs 160mm rotors.
I have acces to the shop I used to work some times, truing stand and quality spoke wrenches and all (I could even check tension if strongly recomended).So build is going to be performed carefully (and somehow skillfully
So,Is that a good idea, you think?
Front
815 Total
Rear
311xtr 960
397mavic
222spokes
41nipples
971 Total
Front +rear=1786
