This is a review I made about the differences I found between the Burner and the Flux. I'm posting it for those looking to make the jump from the Burner to the Flux. Overall, I feel the Flux is a significantly better performer than the Burner, all things being equal, including the shock. I'm interested in hearing your Burner -----> Flux thoughts.
Here goes:
"We went back upstate for an extended run and my first with the
Flux. I also got to hit my normal trails and see what the differences
were.
I noted the Flux excelled in almost every condition when compared to
the Burner.
Over stutter bumps and roots, the Flux was more controlled, this is
despite the stiffer feeling I got from riding. By comparison, I
frequently changed the rebound settings on the Burner during rides.
Our terrain changes radically, so the easily reached knob was handy. The
Burner had a tendency to throw me up on rebound a bit, then I'd have to
dial it down, then bring it back up later in the next section. The
Flux controlled the bumps and the roots better, giving the feeling of
better tire contact with the rear and better forward motion. I also felt like
there wasn't as much chain feedback, but I could be wrong.
On descents, the rear end controlled the bumps and water bars well, and
had less of a tendency to sidestep. Very controlled over these really
poor conditions we have here. It was also noted that it was easier to get over large obstacles, perhaps the lighter front triangle is the reason. The lower bb would make it harder, so it must be the explanation. I took the long downhill to the parking lot at Blue. Got tons of speed going, railed around the rough, rocky turns and more in control. Still, the oddity remains that it felt like there was more control and less motion in the rear over the terrain.
Climbing mild grades was another stong suit for the Flux. The rear end
didn't move under pedaling very much and while the weight savings may
have helped, it wasn't really too perceivable. I can't say it didn't
help over long climbing distances, however. I also found that I was
able to weight the rear end differently. Maintain climbs with my
weight back and use more of my legs in the motions. I also had more of that
"snappy" feeling i the back and I felt like there was more of a
connection between the pedals and the terrain.
Where I did see the Burner excel (all things being equal) was on steep,
rooted, worn out climbs with sand, as everything is out here.
The Burner was a bit smoother, but offered more traction. This may have
been responsible for the "overpowering the rear tire" comment I previously made [to the original recipient] . I took some air out of the rear tire and that slight
weakness became a wash. The Burner's rear end was more active, so
maybe that attenuated some of the torque. The Burner did have a tendency to
allow me to get stopped up on the obstacles on the steep uphills, like
that crack in The Slab. This weekend at Sprain, I was able to power
over the obstacles that wasn't so easy before, while at the same time,
I had a bit less pedal clearance. I guess it just takes time change the
riding style bit and get used to the new frame's characteristics.
The psychological/subjective aspect is a bit different. I actually
liked the bit of activity with the Burner's rear end. It was oddly
smoother and cushier with the Float R PP (while I know the Flux was
designed more closely to match the RP3), but that was the first ride.
The second one where I saw how much more controlled it was over the
Burner over the bumps sold me. It's a bit of a deceiving feeling to
feel the stiffer rear end, while its handles the bumps and tracks
better. Another friend with a Flux and I are going to swap shocks to see how
different they make the bike feel and handle.
Overall, this is a significant improvement over the Burner, once again.
There are subtle differences in all, but they make for a completely
different and better ride. "
As far as geometry goes, I used a 110 stem on my Burner and it felt a wee bit short, but not enough to complain or feel bad. I used this same stem on the Flux and saw the geometry as perfect. Remember the TT on the Flux is slightly longer.
The summation between the two I normally feel is the rear end of the Flux offers more control over the terrain. The rear shock is easier to set up. Getting full travel is just as easy as on the Burner, but the rebound settings are more tolerant of radical changes in terrain. The Burner had a more "fluid", smoother feel in the travel, but less connected to the trail in what I felt in the pedals. The rear end was more likely to bob under power, while the Flux barely moves. I can lean into turns faster and finesse it better, especially on climbs. Not to say the Burner was bad, but I think the Flux is 150% the bike the Burner was. I still loved the feeling of the Burner though, but I got used to the Flux and glad I have it.
Here goes:
were.
the Burner.
