I have been riding my new Burner for a month or so now and the steering/control just isn't where I want it to be. I am hoping somebody out there can offer me some good advice so I can dial this thing in.
Going down fast, tight stuff I always feel like I am on the edge of losing it. It's not the speed. I have been down the same trails on my old bike many many times and not had this feeling at all. I just feel like I don't have the control that I want with the bike.
I think the fork has too much travel but before I bought it I called Turner and they said it should be fine, but noted that the recommended fork was 100mm. When I use the ETA (which is like a lockout but still leaves 25-30mm of travel) I feel like it handles much better in tight, curvy stuff.
I have a 2004 Burner with a
- 120mm stem +-6 degree rise (set on the plus)
- a Zocchi MX Pro 120mm w/ETA
- a titec hellbent XC handlebar
- Mavic 223 rim on the front
- Panaracer Fire XC Pro tires
I've tried...
- moving some of the spacers above my stem thinking that the closer my handlebar is to the ground, the better my control. it didn't seem to make any difference.
- increasing the air pressure on the fork which seemed to help slightly
- using a shorter stem but it was too short and I felt cramped in the cockpit
Can somebody offer me some advice on things I can try? Can I possibly put a shorter coil in this fork to make it a 100mm or 105mm to see if that helps?
Thanks for reading.
I've tried...
Thanks for reading.
