Lastly - I'll confirm a previously reported weight - 7.3 lbs. Exactly same as my old Boxer. Amazing that Marz reports 6.59 lbs.
I haven't done the measurements, but had a bullit and am now on a VPFree. Here's the math, which correlates to your experience.SCDHdude said:Hey Guys - Just put a 66RC 170 mm on my 2002 Bullit and dang it's looking pretty slack. Has anyone actually measured the geometry of this set-up? As best I can tell, the HA is 66 deg or a little less and the BB height is nearly 16"
. Isn't that BB height a little high? (that's a unloaded measurement right?) Wondering if I should get the fork changed to 150 mm. I know I could get a little more travel out of the rear and possible lift it up a little, thereby increasing the HA a degree but then the BB height will be even higher. BTW, I'm a 50:50 DH / free-rider and pedal uphill lots- not a racer or huckster. Appreciate any comments. Also, it that 170 -> 150 swap a DIY job? Thanks. Steve in Santa Cruz
Lastly - I'll confirm a previously reported weight - 7.3 lbs. Exactly same as my old Boxer. Amazing that Marz reports 6.59 lbs.![]()
One note about ETA or Manitou's lower travel setting when using it on a Bullit. I have noticed that due to the change in the angles in the rear suspension that the Bullit tends to firm up in the back quite a bit when the front end is lowered. Several others have observed the same thing. My roommate has an old Bullit with a Z1 and there is a substantial difference in efficiency of the suspension action when the ETA is on.robsetsfire said:You can change the travel of your fork which will drop 20mm off the a-to-c. Marzocchi should be able to give you instructions and parts, so I'd call them. The other option would be to try to trade for a 150mm 05 Z1, since that will drop over 1.5 lbs, give you ETA and still take a lot of abuse.
Yeah, you may like it with the slack angles, a lot of people do. I'm sure it will take a couple rides to get used to though.SCDHdude said:I called Marz - they said it takes some special tools like a stanchion clamp. They will do it for $40 and shipping cost. I called the LBS too - they just send them out to Marz... I think I'll just run it for awhile. My buddies can call me a "slacker" now...
