I'm building my first rig based on a 99 specialized FSR frame.
I'm looking online for all of my parts but i have a few questions I hope someone can help me with.
1. 2 gears in front or 3? if i run 2 gears on the crank must i run 10 gears in the back? What are the advantages/disadvantages of 2/10 VS. 3/9?
2. Do new cranks come with the bearings? For example, if I but a "Sram X7 GXP Crankset 3X9" crank I need to get the "Sram Team GXP English Cupset"? (My frame ony has the threaded hole where the crank should be).
3. "A long cage is for riders who are running a triple-ring up front and the medium cage is for the rider using a double-ring up front." Does this mean that if i am running 3 gears on the crank and 9 on the rear wheel?
4. Will a new SRAM cassette fit onto a new shimano XT rear hub?
Thank you for any help you can give!!
- matt
- matt
