1 - 3 of 3 Posts
Hi
I'm going to be building a front wheel with a Phil Wood 20mm TA hub but I have a bit of an issue. The hub itself is not 110mm wide, instead it uses spacers on both sides to take up the full width of the axle, I'm not sure how I can mount the hub onto a Park TS-2 truing stand that has the extensions for 20mm hubs because the stand only holds the axles at the ends so there's nothing to hold the spacers and the hub together. Has anyone ever had this issue? Thanks.
1 - 3 of 3 Posts
