Well, I have a ski bike. Diamondback Coil full suspension frame, Mantiou Splice fork, BMX lower profile bars and stem, and an internal headset to keep out the water.
I just bought the Hanson Ski-Bike risers and bolted them on some ski blades I already had. Also bolted Hanson's foot peds through the bottom bracket hole. The ski blades I use are a little wider and longer than the ones Hanson recommends, but those guys are running them on groomed slopes 90% of the time. You need more float in the powder. So I run wider 99cm blades.
NOTE: DO NOT FORGET A LEASH!!! If you are going to a big resort and will be using a chair lift, they will require you to have something to clip your bike to the chair for safety. Most times you can hang it by the seat on the rail, but a leash is good to keep from having an accident.
Hansen's kit is solid, but I don't trust the spring mech and the foot pegs are a little small. Otherwise it is fun as hell bombing down the slopes.
