Here's a hot tip for those looking for a nice double crank setup on a 29er platform. Since we all know that the gearing on a 29er should really be reduced by 10% for the size of the wheels, we have two options. Make the rear cassette bigger (hence the new 36t versions), or make the front rings smaller ( hence the new doubles in the 27/39 range. Here was my solution since I was looking for a double. I purpose bought the Shimano M771 version XT crankset new for $175 on sale. It comes with the 26/36/48 rings. Ditch the 48 and run the 26/36. The 36 is more than I ever need on the mountains, and the 26 is fine for me with a 34 in the rear.
Here is the dilemma that had to be solved. The 771 spindle is 6.5mm wider than the 770. The BB is the same as the 770, so there is a plastic 6.5mm spacer located on the ring side of the spindle to account for the added width. Problem is that on the majority of our 29er frames, this offsets the right crank arm 6.5mm out farther than the left, and no you can't center it with the BB shims on a 68.
Call Shimano and order an extra 6.5mm plastic spacer. Remove the original spacer and grind or sand or file the two spacers down to approx. 3.25mm each. The spacers also hold the crank arm seals, so keep the seal in the right one as new and reinstall on the spindle after you file. On the left side, remove the seal from the crank arm and place it in the other new spacer. Now after you slide the spindle into the BB, you add the other spacer with the seal toward the BB, and then the crank arm as usual.
There, a centered crank arm crankset. And to boot you have a slightly wider pedaling platform, which can be an asset on those out of saddle power climbs or that single speed you like to blow past the roadies on.
To the Top
You May be Fast
But Coming Down
I'll make you Last:cryin:
To the Top
You May be Fast
But Coming Down
