Whoa --is that with or without the PUSH mod?
Without. Factory spec 5.5.awai04 said:Whoa --is that with or without the PUSH mod?
What are the changes(if any) between the 05 and 06 5.5s?n10'sGuy said:Paul, That looks like one of the early "hollow" main pivot bolts, we haven't made those for a couple years, changed to solid ones. Call service those should be replaced free of charge.
Dang what happened? I've taken my 5.5 dwn Vail, Keystone, and Winter Park this summer and it stills rides like new.I know it's hard to tell, but could the swing arm get broke under braking? I know that I broke 3 swing arms at the same location on my RTS I think while under braking.The broken bolt thing could that be caused by over torqueing at reassembly?Paul B said:Strike one was a broken rear swingarm. Different issue.
p.
I have an 04 5.5, one of the early ones (without the easton sticker) and I'm wondering what the deal is with the solid bolts? Stronger is obviously better in this area.n10'sGuy said:Paul, That looks like one of the early "hollow" main pivot bolts, we haven't made those for a couple years, changed to solid ones. Call service those should be replaced free of charge.
JRA through a modest rock garden in Flagstaff, AZ. 12 miles of pedaling with the swingarm splinted by a spare tube and a box wrench.dorsett said:Dang what happened? I've taken my 5.5 dwn Vail, Keystone, and Winter Park this summer and it stills rides like new.I know it's hard to tell, but could the swing arm get broke under braking? I know that I broke 3 swing arms at the same location on my RTS I think while under braking.The broken bolt thing could that be caused by over torqueing at reassembly?
We do. Blue loctite works to a degree. The surface of the bolt is hard anodized which inhibts the effectiveness of blue loctite. There are specific thread lock's that work with anodize but bike shops and bike owners don't have it or use it, so we use blue.peachy-B said:^^^ u didn't ask Nick why they don't add the loctite on the main pivot right at the factory?![]()
I asked about buying them a while back but they are kind of pricey. Its a custom machined bolt. I think they said something like $27 each.Pedal Bike said:I have a 2004 5.5 with Hollow Pivot Bolts.
Do I need to replace them with solid bolts?
Does Intense offer this replacement?
I got a 2004 frame, the non-drive side bolt is hollow for about 3/4 to 1 inch into the bolt. Is that considered the hollow bolt? Or does the 'hole' run through all the way to the other side?Paul B said:Last item:
The new bolts do look "solid" compared to the broken one, which is obviously hollow. Totally negligible weight difference; here's hoping they're actually stronger. The rearmost bolt in the old swinglink, the one that didn't break, is also "solid." It'll be good to have a spare.
The hollow bolt that broke was hollow all the way through. The solid bolts I ended up with are solid all the way through AND have a very shallow groove machined in just below the bolt head, into which the set screw tip will engage. It's a very nice looking piece of hardware -- I only wish I had photographed it before installation!yewweng said:I got a 2004 frame, the non-drive side bolt is hollow for about 3/4 to 1 inch into the bolt. Is that considered the hollow bolt? Or does the 'hole' run through all the way to the other side?
