I just got new pads for my Saint breaks, problem is the don't clear the rotors. I pushed the pistons back into their original positions, and re-adjusted the break system so it's perfectly centered with the rotors, still know luck. The pads are just too thick to clear the rotor.
Anyone else have issues like this before?
Yes I have the proper pads, ect... just don't clear right.
So the only two things I can think of are;
1. Do I need to wear down the pads some how, untill they slide in? If so, how should I wear them?
2. I'm not running the Saint rotors, does Shimano machine their rotors thinner than most other manufacturers? If this is the case, the previous owner must have ground down the last set of pads he used. So again, how would I do this?
Any other possabilities for the problem and solution are welcome.
PS, I also replaced the RD, got the X-9, and the shiftings a bit rough, any quick tips to improve shifting smoothness and eliminate ghost shifting/cog skipping? (I'm too lazy to make two threads for both questions.)
