You mean you need to pull the lever farther, and you have less braking power? You moved the pads out too far. Typically, the cause of rubbing on BB5's is you didn't tighten the CPS bolts enough, and repeated braking pulled the caliper outwards, making the inner pad rub on the rotor. Set the brakes up again. Loosen the mounting bolts, get the caliper centered by moving both pads in until they contact the rotor, then squeeze the lever hard, but not so hard you start bending things. Nice and firm, just enough to compress the pads a bit. While squeezing the lever, tighten the CPS bolts down good. Don't go gorilla on them, but get them tight enough the caliper won't move. Then back each pad off, one click at a time, until the rotor doesn't rub. Usually just a couple of clicks does it. I prefer a bit more gap on the outside pad, gives a little more "feel" instead of insto-stop. Just go slow. My guess is you moved the inside pad too far away. It's stationary, the outer pad bends the rotor in to hit it. Move the inside pad too far away........more lever travel needed to get the rotor to meet both pads, less stopping power.
