brake upgrading...
795 Views 11 Replies 7 Participants Last post by  RobsterCraw
i ride a 04 rockhopper with marozzci (spelling?) mx comps. my current brake have not been replaced/worked on since i got the bike. now, they suck. i was wondering if i should replace the pads or the entire brake system, or get fornt discs (if is possilbe on an mx comp)...so anyways i need your help
thanks in advance:)
1 - 12 of 12 Posts
How can anyone answer your questions with any kind of a meaningful answer? There's so much we don't know.
Ok I'll take a stab with what little you've given. Get a full brake tuneup - new cables, new pads, lubed pivots, adjustment. Now, do the brakes perform acceptably under your riding conditions? If not get disc brakes, or ceramic rims.
dogonfr said:
What brand brakes do you have :confused:
tektro i believe
to be more specific, when i pull the brake handles, i feel they travel too far a distance till the brake pads touch the wheels, and when the pads touch the wheels, the bike takes too long to stop
anything else?(not tring to be sarcastic question)
Bring it to the shop and get a brake adjustment. About 15 bucks.
Simple adjustment seems in order. A few seconds' job.
The pads could be worn out, contaminated, rims glazed/contaminated, cables partially seized/contaminated. The list goes on!
Pfft you dont need new brakes. Replace the pads! Clean the rims!
That sounds like you need to tighten your brake cable's,also try tighting the adjuster on your lever,and if you have tektro levers get some new levers becuase the tektro levers are wak and you dont get naff all power out of them the v-brakes are ok and you can get power out of them with some good levers.
what pads do you recomend? how should i go about cleaning the rims?
"Simple adjustment seems in order. A few seconds' job."
what adjustment?could you tell me a link where it shows how to do this?
1 - 12 of 12 Posts
