1 - 14 of 14 Posts
Hey all, have a Fuji Cross 1.3, love the bike however came with BB5's which I only learnt after I bought it are pretty crap. I'm sick of the constant adjustment and being halfway through a ride and having them start making noise etc...get home, more adjustment, takes too long, can't get them right etc....ehhh anyways, time to upgrade.
I don't ride cross races, I use the bike to commute to work, about 28km each way, and do long rides over the weekends, up to about 100km over gravel and road. Want to get better and go on some singletrack etc...
I've looked at Avid BB7's, recently started reading about the TRP Spyre and Hy/Rd (which i like but don't know about the level travel on my SRAM Rival gear).
Wondering what you lot run and can recommend, budget isn't much of a concern (just means a longer savings plan hehe) - I like the looks of hydraulic however really I just want something that doesn't require constant adjustment that'll stop a 95kg man (wishing he was 85kg) when going down a hill. Which my BB5's aren't great at :)
Thanks all.
powered by peanut butter.
XT won't work with drop bars. I've heard BB7 are a whole lot better than BB5, but I haven't used them myself.
Teen Wolf
just got a set of bb7's on my cross bike, so far, so good. really like them. i've been running them on my mountain bikes for many, many years with success. i'd recommend them over the bb5, but i'd definitely shop around, especially if money isn't a concern.
Discussion Starter · #7 ·
Thanks all. I'm pretty much hearing that the BB7's, Hy/Rd's and Spyre is good. I think Shimano and SRAM have taken down their hydraulic's from their websites due to recalls...
I'll start looking into the above 3 brakes some more!
Discussion Starter · #8 ·
switched from bb7s to trp Spyre dual piston mechanical discs. Great brake
<img src=https://tfe.me/image/480_345/BR7745.jpg>
Does it require much maintenance? Being dual piston I'd think u could get the rotor pretty much dead centre then set and forget, only adjusting for pad wear?
Discussion Starter · #9 ·
I upgraded my 2014 Jake the Snake to the TRP Hy/RD brakes. I only have a couple hundred miles on them but they have been great so far.
I think these are sitting at the top of the pile for me, I just keep reading that you have to pull the lever all the way to the bar to get them working? Have you found this?
Yup. Using a 3mm hex wrench just set each pad an equal distance from the rotor, center the caliper over the rotor and adjust the arm tension for modulation and that's it. They also dont suffer from brake fad like the bb5s and 7s do.
+1 on the TRP HY/RD. Just installed on my Niner RLT to replace those awful BB5 that came with my build. Great modulation, great power. They aren't on the same level as the XT's on my mountain bike, but for the road/gravel... perfect.
May have also been the easiest brake install I've ever done. First set of brakes I've ever installed that didn't rub the rotor off the bat. This video is a great tool to study prior...
I usually only need one or two fingers while still on the brake hoods to do most of my slowing. Heavy braking requires a little more involvement but I have not noticed that I pulled them all the way to the bar yet. Even Sunday's panic stop to avoid running over an unleashed dog didn't require a bar pull.
I did get lucky in the fact that the shop I bought the bike from installed them for free during the initial assembly.
Discussion Starter · #14 ·
Thanks all!
I went back through the bikes I test rode as i remembered that 2 of them had hydro brakes...a Jamis and the Trek Crossrip ltd...well well well, wouldn't you know it, both TRP Hy/Rd's.
The Trek I didn't get to push really at all but the Jamis i gave a bit and still remember walking back in and seeing the guy telling him I wanted the bike just for the brakes...
TRP hy/rd's it is!
1 - 14 of 14 Posts
