1 - 9 of 9 Posts
Premium Member
Right now I have been really enjoying the Code R brakes on my Heckler. They are very easy to modulate and have plenty of travel to allow for a gradual slowdown. They can also really bite when squeezed hard.
When I get my Rise M20, I’m thinking of upgrading the brakes to Code RSCs. Does anyone recommend any other brakes that have similar levels of modulation feel and stopping power
I like my code rsc although a caliper bit the dust recently. You could try Hayes Dominions. Off the top of my head that would be the only set that I can think that is pretty user friendly and is not going to be more on-off like Shimano (I like Shimano brakes).
Other options that are less user friendly would be Hope and Magura
If you have the money and more importantly the time: TrickStuff
If you work on your own stuff and like quick and easy, Shimano XT's. I've had 2 pairs for close to 10 years, both still in use, couple minutes to bleed without any b.s. or headaches. I do love the feel of sram, but choose shimano on maintenance alone.
If you like the feel of SRAM brakes, then it does make sense to stick with them.
I'll also mention TRP, as they have a somewhat similar feel to SRAM stuff (TRP is also known for being on the more modulation side of things), and the Hayes Dominion brakes for similar reasons.
I concur, your hono(u)rs. sounds like you've found what you like already.
Spending more money for the sake of an upgrade I always like to address something that I want and I'm not getting from my current gear.
I blid my 2yr old set of Clarks M2s a while back and replaced the pads with Shimano g04s. I got the set for like 50 bucks. I like them as well as any other brake I have (except for the Shimano ones that you can flick the levers away from the bars - I just love doing that when I'm climbing) and I've been using them on my camping hardtail for a couple years which has been taken up and down some big shizz before the fam awakens and I'm confined to pump track & blue trail duty. I don't work for Clarks btw. (but hey, I'd never admit it even if I did as they're not that 'cool')
1 - 9 of 9 Posts
