Blue Shorts said:
The thomson clamp is different than the others. The other brands wrap completely around the steerer tube. The thomson is completely different...look inside.
Yes, I know what a Thomson Elite stem looks like. I've got two of them. By the way they also clamp all the way around. When you tighten the wedge, the stem itself is pulled tight against the steerer tube. It is not just the wedge that is holding it.
I tried a search by the way for a string on the subject using "Thomson and Chris King". The search engine came up blank.
I found the following on the King website (FAQs):
"My headset won't stay tight--It just keeps coming loose.
A properly set up Chris King headset shouldn't need adjustment more than once or twice a year (depending on riding style). If your headset needs adjustment more often than once a month, check for the following:
Threadless models:
1. The pinch bolt on the stem may not be tight enough or the clamp method may be inadequate. We have found that stems with a split and one or two pinch bolts hold better with less chance of distorting the steerer tube than internal wedge designs. Solution: Tighten or replace the stem.
2. Steerer tube may not extend far enough into the stem. Solutions: 1) If spacers are being used to elevate the stem, remove as necessary to lower the stem to within 3mm of the top of the steerer tube; 2) Replace the steerer tube and be sure to cut steerer tube to extend to within 3mm of the top of the stem (steerer tube must not interfere with the stem cap).
3. Steerer tube may be pulling through the crown. This is more common with older suspension forks. Solution: Contact the fork manufacturer to determine the proper remedy for the steerer tube pulling through the crown. 4. Demanding applications (such as trials and BMX) can generate strong leverage on the handlebars and walk the stem up the steerer tube. Solution: In this case it is best to extend the steerer tube through and above the stem. Spacers may then be used on top of the stem to allow proper functioning of the stem cap. (We learned this trick from the boys at GT BMX racing.)"
Pretty vague I'd say. So maybe someone at Chris King doesn't like Thomson. The fact is you would need to be King Kong to get a properly installed Thomson stem to move. So, assuming that it is properly installed and properly clamped the above is hyperbole.
Ronnie.
