1 - 20 of 20 Posts
· Registered
My brake rotors havea a "wobble" to them, I don't know how to say it. they rub the pads at points, I can hear the rubbing when i'm riding, and it bugs the s**t outta me. SHould I be worried about this at all? Is there any way to fix it on my own?
· Registered
Lickqid said:
My brake rotors havea a "wobble" to them, I don't know how to say it. It rubs the rotor at points, I can hear the rubbing when i'm riding, and it bugs the s**t outta me. SHould I be worried about this at all? Is there any way to fix it on my own?
try bending it back or get a new one.... unless it's waaving like 1/2 inch then it's not bad... you can always pick on up cheap on ebay.
· Meh.
They're warped. You can gently push on the arms of the rotors where it has a wobble to push it back into shape. Incorrectly torqued bolts or incorrect order could also cause the rotor to warp.
· aka Jesse Palmer
I like to use a long allen key or somehting then just find the points on the rotor where it comes closest to the pad and tweak the rotor out by sticking the allen key into the rotor so you dont get your grummy hands on there. If you want to go crazy and you have an extra $100 burning a hole in your pocket you could buy one of these and really get it perfect...
· noMAD man
If you don't feel confident in trying it at home with an adjustable "crescent" wrench, most shops have a cool 3-piece tool set of weird looking forks that fit brake rotors, and when used in pairs or all 3 at a time, they can straighten out some pretty whacked rotors. I've straightened 2 or 3 rotors at the shop with these things that I would have bet didn't have any hope. They're also not that expensive from some tool makers if one is a home mechanic/racer type who frequently dings rotors in rocky situations.
· Glad to Be Alive
could you post a link of this tool
1 - 20 of 20 Posts
