So, I just mounted up my new XTR brakes, front is fine, but the rear is not.
I thought my rotor might be shot and sure enough it is. There is a very noticable ledge between the running surface and the support, and it is getting bigger quickly.
I will change the rotor and see.
My question is, why, this occurred very quickly, and only on one rotor surface (outboard rear), are the rotors surfaced hardened so once you wear through the wear rate increases quickly??
