1 - 20 of 35 Posts
· Older than I feel
Before anyone gets the wrong idea, I already have a new Hope hub to replace this Chinese piece of... poorly prepared but good looking aluminum. Lesson learned, but fortunately not too costly.
The first time I installed a rotor on this Goldix hub, 2 of the 6 bolt holes stripped. And I had barely put any torque on them! I tried to clean up one of them with the appropriately sized tap. I knew it was a long shot, but nope. The vendor (the GOLDIX Store on AX) said "it was you who screwed the threads, my friend." Thanks a lot.
Is there any way I can put some threads in this thing, say with a Heli-Coil or similar? There's not a whole lot of material there - see the pic. The buggered holes are at 5:30 and 10 o'clock in the pic. Or is it destined to be a paperweight?
Locking hubs Motor vehicle Bicycle part Rim Auto part
· Older than I feel
Discussion Starter · #3 ·
No. There might be 7mm or so between the back of the rotor flange and the spoke flange.
Looks like the material around the holes is maybe 1.5mm at the thinnest point. I'm not optimistic about getting a threaded insert in there.
· Registered
get a thin nut. 7mm is more than enough. Get some slightly longer bolts, glue the thin nut to the backside.
Here’s some additional resources:
Measure existing bolt, will probably be around 10mm, get a longer one. Disc brakes take m5 (I believe) bolts, get some stainless ones, torx so they don’t strip out.
Then get a 5mm nut, something like this:
It’s less than 3mm thick, put disc bolt through as usual, but this time pick up nut on rear, torque as usual. Glue nut in place for ease of install.
· EAT MORE GRIME
(ノಠ益ಠ)ノ彡┻━┻
just don't use it, not worth something going wrong. it can be tapped and coiled but you lose integrity since the ears are tiny to begin with.
back... who cares...
front ? facial fractures suck
· Registered
Helicoils are really strong, stronger than existing metal. You can make it work if you want. Ride that damn wheel into the ground, show it who is boss.
seems like something might be amiss with the aluminum though, shouldnt be so soft. Good aluminum is really hard and tough, not peanut butter. Maybe get a hardness test done and see if it matches manufacturer’s specs.
· EAT MORE GRIME
(ノಠ益ಠ)ノ彡┻━┻
<...snip...>
yeah.....no to that....
Forehead Nose Cheek Eyebrow Mouth
1 - 20 of 35 Posts
