1 - 5 of 5 Posts
I thought I'd get more responses here so I hope it's okay with the homies.
Whilst enjoying the build experience for my new Flux, I discovered that my Hope X2 brake will not mount properly to my RS Reba post mount. When I put it on, the caliper sits above the rotor about a 1/2 inch and not covering the pads. It lines up correctly, just doesn't allow the caliper to come down onto the rotor fully, making the brakes unuseable.
I have the correct "H" mount adapter, which is for 183 rotors, post mount caliper, post mount fork. I called Hope and they said the post mount on the fork is incorrectly mounted and that i should get a new fork. Yikes! I have a hard time believing RS would be that poor with QC and incorrectly install a disc mount.
Now I have to find a buddy with a post mount fork and see if it's the post mount on my fork for comparison, or the adapter.
Anyone else have such a problem? Help.
Discussion Starter · #3 ·
Yep, its stamped 183 on the rotor. The specs I mentioned on what I've got are all correct.
ride
Try orienting the adapter the other way. There is nothing wrong with the current Reba castings...
here you go, hope post to post 183 rotor
if the fork is ok all it can be is a upside down mount or the wrong mount
1 - 5 of 5 Posts
