1 - 6 of 6 Posts
· Registered
Hi everyone! I’m just new here and want to ask for help and advice .
I’ved bought a used Shimano XTR BR-M9020 calipers only . Is it possible to use the new model BR-M9120 Levers for this calipers ?
I bought the calipers for around 140USD, Did i made the right choice or not ?
Thanking you all in advance !
· Registered
I don't think they will fit. I have newer 8120 and broke the lever . I tried to use 8000 levers and they don't fit. I would assume the same for XTR. The older lever was physically wider and wouldn't fit.
Sent from my GM1915 using Tapatalk
· Registered
Discussion Starter · #5 ·
Yes, you can use any of the Shimano levers with any Shimano caliper as long as the hose connections are the correct ones for your application
I went to a bike store and ask a mechanic there . Just like what you said , he said that it's possible to use the new M9120 brake levers .
I think they uses the same brake hoses , right ?
But i'm not sure if the performance is the same or over kill and might cause any brakage on the calipers piston . Isn't the M9120 4 pistons/pots ? The M9020 only has 2 piston . What do you think ?
1 - 6 of 6 Posts
