1 - 3 of 3 Posts
And He was Not
A friend of mine showed up @ the house tonight with a 2002 Marz 29 Fork. My Hayes adapter bolts up but the Caliper angle is way off. Can anyone tell me what adapter this fork uses in order to run 160mm rotors?
Premium Member
The fork has normal IS disc tabs. Just make sure you are using a front mount.
I don't know what are problem was tonight Jerry.
I came home and fiddled with the adapter bolts and got the caliper to slide over the rotor OK and had everything lined up in no time.
I guess that they are 51mm IS but they looked a lot different then the stuff we are used to working with like the Fox,RS, and some others.:madman:
1 - 3 of 3 Posts
