:eekster:
Still only 120mm!
Still only 120mm!
So looks like the brain is coming down the model line :thumbsup: (Pics of the S-works Stumpy below)singletrackworld said:The S-Works and Pro models will have the new Specialized shock, with the Expert model having an original Fox remote Brain shock. The Comp model will have a regular Triad shock.
This is plenty enough!!! not satisfied, get the enduro!anand said::eekster:
Still only 120mm!
think thats a typo. The 2006 fsr s-works has 130mm of travel. Doubt they went down in travel.anand said::eekster:
Still only 120mm!
and? they did this in previous years as well, not to mention the s-works enduro back in '03. this is not new.crisillo said:So looks like the brain is coming down the model line :thumbsup:
Yeah, but on the STUMPY line, only the S-Works and Pro had it, now the EXPERT will have it too (it's on my post's title).Cyco-Dude said:and? they did this in previous years as well, not to mention the s-works enduro back in '03. this is not new.
the bike pictured is an s-works, so its made out of carbon, not aluminum. i should hope there are no welds on a carbon frame! also, if you look closely on the rear triangle you'll see the typical welds (rear stays are aluminum).pimpbot said:... seemless weld thing? Are they doing like c'dale where they do ugly, overheated cottege cheese welds, then grind them out smooth?
