The alloy and carbon fibre rear swingarms on the Epics always seem to have slightly different designs. The differences are more than just the material they're made from. The 2009 Epic had lots of design revisions to its rear swing arm in order to address small issues.GTR2ebike said:Not sure if you noticed this or not but it's because the mounting of the line is different. The s-works has a guide bolted into the connection of the seat stays(closer to the middle of the bike which is why it rubs) the evo has a wire tire to the seat stay. This was probably in an effort to make the s-works look cleaner.
I'd suggest putting a piece of protective tape around the seat tube, unbolting the mount and wire tire the hose to the seat stay.
http://www.crankskins.com/20mu20.html Try a piece of that 20 mill tape on the seat tube and on the hose, should take a while to wear through.goneskiian said:I guess I'll try to get some tape in there too. Thanks for the idea. That'll protect the frame but the hose is still wearing through.
Cheers!
Is the brain hose always directly touching the seat tube, or just at particular sections of the travel? It might be that the prototype brain hose was thinner than the hose used on production shocks.norty_mtb said:WR304 is correct. No camera tricks. It is so tight that I can't even squeeze the protective tape in. The hose does not have enough slack to move over and use a zip tie(the evo has a zip tie hose mount on the seat stay). Like WR stated, even if the hose had the slack to move it still has to fit between the rear triangle and the seat tube.
Fixes...
1. smaller diameter brain hose
2. longer hose routed outside the seat stay
3. redesign the rear triangle to provide more space like the aluminum version
4. ???
I'll leave it to the experts to figure a fix. Until then I'll keep an eye on mine.!
Fixes...
4. ???
