No no spacers are you sure you have the right axle for the fork ?
My boxxer is actually a couple mm narrower than the hub, it takes just a couple pounds of pressure to spread the fork enough to get the hub in. Sounds like your hub is too narrow or has the wrong endcaps on it. I was on a budget, and got a 20mm "rocky mountain" hub from Cambria when I got my boxxer. It was $40, down from $100. Not my first choice, but it'll have to do for now. Maybe you can find the right caps for your hub???josiahdood said:There definately aren't any dust caps (maybe i should get some), theres like 5-7mm of space between the hub and the legs of the fork. The only thing thats keeping the hub from sliding on the axle is the brake. Does this mean I need to get a completely new hub? Agh! The throes of buying a bike on ebay...
You're missing something.josiahdood said:There definately aren't any dust caps (maybe i should get some), theres like 5-7mm of space between the hub and the legs of the fork. The only thing thats keeping the hub from sliding on the axle is the brake. Does this mean I need to get a completely new hub? Agh! The throes of buying a bike on ebay...
