1 - 3 of 3 Posts
fraid of heights
You'll probably laugh at this question. But does anyone know if I switch the plastic "all travel" spacer from the bottom of the spring to the top of the spring on my boxxer to give it 7 inches of travel from the six it came with. Will it sit an inch higher? Or just go down another inch into the fork on compression? :)
I'm thinking it would raise it an inch, which would be cool to see how the bike rides with the slightly slacker headtube angle. But I wasn't sure.
Also, if anyone's made this change. Did the change in travel mess with your sag enough that you had to get stiffer springs?
Thanks!!!!
1 - 3 of 3 Posts
