1 - 15 of 15 Posts
So, I have a rockshox deluxe select plus with a megneg air can installed. At first, it consistently leaked air, riding or not, since then I have fixed this by putting more grease on all the seals.
My new problem with the shock is this: about 1-1.5 months later, my shock leaks air again, but only when I ride and only when I bottom out on that ride. I noticed that my shock had lost about 30% sag (30%-60%) in one ride.
Later, I pumped up the shock to 30% sag and it remained at this for a ride where I did not bottom out the shock and for 2 or so days after this ride.
But when I went for a ride my shock kept this pressure, until I bottomed out a couple times, when it quickly lost about 20% sag(30%- about 50%).
Note: since the shock lost that pressure it has not lost anymore.
Does That mean the shock losing air is bottom-out related? And how can I fix this?
Thanks so much for any help!
Discussion Starter · #4 · (Edited)
Is your shock sitting into sag without any weight on the bike?
Thanks for the reply, by sitting into the sag do you mean like 10% or only about 5%. because it does 'sit in' a little after it is compressed, meaning that after compression i can pull up on the linkage so that the shock de-compresses more. ill attach some photos
This may or may not be relative... I mention it because you recently greased seals.
I had a similar problem with a Float X, but after hard riding it was actually "sucked down" a bit and sitting at sag without weight on the bike. I also thought the shock was losing air, but it was actually trapped in the negative chamber. When I would force the shock to extended into topout and cycle it multiple times, it would slowly equalize and the pressure would return.
I never bothered to solve it as it was at end of service life, but I'm pretty sure it was because the oil was blocking the eq ports.
Discussion Starter · #14 ·
Thanks, I'll give this a go
Discussion Starter · #15 · (Edited)
Unfortunately no
1 - 15 of 15 Posts
