Serious question: what do you think is wrong that is directly related to the bottom bracket bearings, themselves, that won't be present in other systems?
(hint: it's probably not the bearings if they aren't notchy, it's probably the setup; are the threads aligned with each other, are the faces of the shell aligned with each other, and are the threads prepared with something--grease, threadlock, teflon--and is preload on the bearing set properly, etc...)
