Bottom Bracket sizes.
729 Views 3 Replies 3 Participants Last post by  AZ
The spindle lenght on my old bottom bracket was 122 mm's. Would it be ok to use a new bottom bracket with a spindle lenght that's 4mm's smaller or lager? Which would be better?
1 - 4 of 4 Posts
Spindle length has to do with the specific crank you're using and the chainline you're shooting for...what model crank do you have?
Shimano Deore (single chain ring) on a scott voltage 2(dirt jump bike/dual slalom). Now geared in the back but soon it will be a single speed.
If you run the chainring in the middle position a 118 mm spindle should work .
1 - 4 of 4 Posts
