1 - 4 of 4 Posts
Does anyone know what bottom bracket went on a 95 Proflex 955 frame? I did a search here but didn't find anything about the bottom bracket. I have a 68x113 that fits but the spindle is looking a little short. Any help would be appreciated.
Mantis, Paramount, Campy
Spindle Lenght Depends On Crank Arms
That 113 spindle is probably right for 1995 generation XT, LX, etc cranks.
Older non-low profile cranks will need something about 10mm longer.
What crank are you planning on using?
Discussion Starter · #3 ·
I have an old set of specialized "son of strongarm" cranks I plan on using. I put them on and took a long look, then got that feeling of the spindle not being long enough. Thought I would check here before I went any further with the build up. Thanks again Shayne.:thumbsup:
I'd Guess That 113mm Is About Right
For those Specialized cranks.
Give it a try and see what happens. I can't imagine they'd take anything longer than a 118mm if the 113mm is too short.
1 - 4 of 4 Posts
